Reverse Bulbs + License Plate Bulbs
Husker1111
Omaha,NE / Tampa,FL
I want to get brighter reverse light bulbs like leds and license plate bulbs. I dont want to buy an HID kit tho what are your guy's suggestions and where should i buy them? I want them to be pretty bright,
01TX_Tahoe
Semper Fi
Pasadena, TX
i used the sylvania silverstar for my reverse lights and they are BRIGHT! big difference from the old bulbs... now i can see! as for the license plate bulbs...LEDs. thats what i have and they look pretty good.
Lowered On them Thangs
Greenville, North Carolina
Go with the new line of PUTCO L.E.D.S. they will run you about $40 for the bumper lights and $25 each for the reverse lights, but the best thing bout these lights they have a LIFETIME WARRANTY and no fine print...if it is not working or going in and out they give you a new one right on the spot!!!!
thehoe92
fo sho
The916
you can get brake lights, reverse lights, and turn signals for under $25 each side
http://www.superbrightleds.com/cgi-...tion=DispPage&Page2Disp=/tail-brake-turn.html
thats if you with the cheaper bulb.. it will still be brighter than stock
3157
and 194 for the license plate lights for only $2
http://www.superbrightleds.com/cgi-bin/store/index.cgi?action=DispPage&Page2Disp=/mini-wedge.html
I've read getting the brighter ones doesn't do anything
even swapping them out for new OEM bulbs will be brighter because the other ones could be burned on the outside of the bulb causing it to spread as much light
H
Husker1111
Omaha,NE / Tampa,FL
3157
hey just ordered all the bulbs for the interior, puddle, and license plates in led from superbright led
wx646
NYC
