Reverse light LED replacement and picture quality
AngelXL
I believe they all going to look like that.
I have 2 other Lexus trucks with OEM factory LEDs. They all the same. Don't go crazy with this... it gets use for no more than 2 minutes...
C
cardude2000
Oh I'm not going crazy with it. Just curious if everyone else's is that bad. I learned long ago not to compare chevies (regardless of badging) to Audi and merc.
I put these in: iJDMTOY Extremely Bright 5-CREE 25W High Power 912 921 920 T10/T15 LED Bulbs For Car Backup Reverse Lights, Xenon White https://www.amazon.com/dp/B00CORBQUA/ref=cm_sw_r_cp_api_-wgwybF4EQW0V
They look great but the backup monitor is still really bad (this is my second try with leds)
Any suggestions?
Mine also looks similar to yours. I'm running led's in my reverse lights also. At least it looks good during the day! Lol
ajs800
Michigan
There is another thread on this, with pics, and there are some that provide much better rev cam images. I am currently running the phillips and plan to either go back to the orig or another type that is mentioned on this board. I've been in many other vehicles with OEM led reverse and they are 10x cleaner than the phillips I'm running (it's all show.)
I see that your is one that was highly recommended. I'm sure you read the posts but I believe the other one is from superbrightled.com. it was stated that they both offer a much better image than the phillips 921.
C
cardude2000
Yeah I had leds in and then bought these based on the other thread. Maybe 3rd time will be a charm.
ajs800
Michigan
keep us posted as I'm in the same boat and plan to purchase another set. I'll go back to the halogen if the others aren't much better than the phillips.
EBALLEN28
