Reverse Lights
awkisan
My Dome lights went out and my reverse lights. Can anybody tell me which fuse(s) control the reverse lights and the dome lights in a 2006 Yukon Denali XL?
I've looked in the manual and checked the one's that correspond with what they say, but no luck, they are good. I've even put a meter on ALL the fuses and couldn't find a bad one.
Thanks in advance for any help!
chauncey0337
MLT, WA
Did all the domes and reverse lights go out at the same time? Strange if they did. Also, I'm sure you know since you read the manual, but there's fuses under the hood and in the cabin.
I'd make sure the reverse bulbs are good and make sure the dome override is not on.
A
awkisan
Ya, I checked em all (through ground). All fuses were good.
I haven't checked the bulbs, I will tonight.
Thanks for the response.
DenaliAK
Colder than you
Alaska
Yeah, I've hit the dome override button a few times accidentally. The first time was the most annoying, because I didn't even know there was one, so it took a while for me to figure that out....lol.
GeneralNoobzor
Phoenix, AZ
To the best of my memory, the fuse is named TCB 2. It's in the fuse box inside the cabin, behind the panel under your cluster. :) 15amp mini
A
awkisan
Thank you
I will try that one.
Thank you!!
You are the man!
drackill1
