Roll pan confusion?
HoeRyder26
Mass
Hey guys I was on ebay looking for a bolt on steel roll pan for my 03 tahoe lt, and I saw a limited selection for the tahoe. My question is does a silverado roll pan fit? When you look the silverado up there are way more results, cheaper too.
Duramax05blk
NH
Ya I had same issue I ended up getting a fiberglass. I did see a few steels but where all weld in and no plate spot. No the silverado won't fit
Sent from my SM-G900V using Tapatalk
Duramax05blk
NH
Work s slick with a body lift and trailer hitch. Some additional bracing helps the fiberglass pans stay sturdy.
Behind the plate bracket I added an aluminum plate to mount plate bracket just got finish machining to go around hitch. I also added plate stops the Lil brass pieces to stop plate from smacking the paint when ever that happens, there 1/4 20 tapped to thread some rod into turn buckles welded to hitch
lordmorgul
