Roll Pans
Ninety5PoloZ
Wisconsin
I'm ordering one in a few weeks, but would like to see the different styles. I was going to order one from summit since they are only $100 but they are fiberglass and I kinda want steel, but for the price I don't know.
But post some pics of your rollpan and some info of where you got it.
JKmotorsports
Austin, TX
I would stay away from fiberglass if possible. Steel and urethane will hold up much better. Steel is easily repairable if you bump into anything, and you can weld the gaps between the pan and quarters for a seamless, clean look. Urethane is flexible and not near as easily damaged as fiberglass, which will crack if you bump into something or lightly rearended.
I have a urethane piece from stylintrucks.com. They have a decent selection of steel and urethane rollpans.
AtomicHoe094
Atomichoe094
cleveland, OH
foreverfalcon40
STEEL I HAVE MINE...it surved 2 accidents. If it was FB it would have been replaced!
Ninety5PoloZ
Ninety5PoloZ
Wisconsin
I'm pretty sure the trucks are different than that tahoes and surburbans, but I gould be wrong.
I'd like to get a steel one, but I really can't afford to spend $250 (Sir Mikes) on one for a while. But Icould drop $100 and not have to worry about it. If I did get steel I wouldn't weld in in just incase I were to get rearended. But if I did the person responsible would have to pay for everything :)
I was curious if anyone has used the summit roll pan to see how it fit. If its going to be way off then I'll wait for the Sir Mikes but I'mstill looking
Thanks guys
AtomicHoe094
Atomichoe094
cleveland, OH
i cant remember why my rollpan was sooo cheap at the time.. it fit perfect and welded that SOB right on in.. hmmm ill keep looking for ya tho!
foreverfalcon40
Save for steel it will save you in the long run. If I had FB I would have been on 3rd one. Both due to hit and runs. If you get rear ended you won the lottery anyway.
U got Hit N Run twice therefore I'm the Loser.
blanchard7684
