RPM Surge at idle...
Rollin Thunder
Banned for Repeatedly Insulting Members
Va Beach Va
Only seems to do it when I first start it and if its wet or humid out. It will serge between 400 rpm and 800 rpm. just up down up down up down. I shift out of park and it stops and does not do it until our next humid day or rain storm. No idea why its doing this.
Rivieraracing
Clean out your throttle body, not saying that is the reason, but probably dirty and might solve your problem!!
mike03tahoelt
yeah mine was doin the same thing but all the time its always humid in florida i cleaned the throttle body and seafoamed and its gone
DenaliAK
Colder than you
Alaska
For a complete non-mechanical type like myself, how does one clean the throttle body? (or even find it?)
BlueTahoe2001
Charlotte, NC
RT, I am having the same problem. I think it may be the Vacuum piece. Can't think of the exact name right now!
DenaliAK
Colder than you
Alaska
lols...thank you. Sounds simple enough. I'll look. I'm having a surge issue as well, but mine is at speed.
mike03tahoelt
just pull the big tube going into the middle front of your motor spray some carb/throttle body cleaner have someone hold the throttle all the way down with the car off and wipe with a rag
Shadfrmdabull
