running a little rough
94yukongt
Ok so the other day my truck started to run a little rough at idle. It has new plugs, msd wires, accel cap n rotor, msd coil is all new. About a month ago my aftermarket cat was clogged and i beat on it and it blew out some particles and it seems to run better. I think my cat may still be a little clogged which is causeing the running rough issue but idk. please help. thanks
ChiTahoe
Your ignition seems to be in order but, I have seen MSD wires fail. I would venture to say you should get rid of the cats and replace with a test pipe or replace them. Those cats are definitely effecting performance.
SunlitComet
OBS Jedi-Do Good
unknown at this time.
I would advise that since you have seen converter damage already you should perform a exhaust back pressure test to confirm that your system is clogged.
94yukongt
thanks guys. Im looking into doin my whole exhaust over so deff gunna get rid of the cat.
FPinzon
