Running like a bullet
Popeye
Popeye
Ontario, Canada
I verified using a OBD monitor plugged into the vehicle and the computer sees all the reading normal but the cluster is pretty much gone 'ape' on me. At 2000rpm i am doing only around 110Km/hr (as per the GPS and OBD monitor) not 160 as it shows.
Anyone know the fix to this or is there one? Pretty annoying actually.
96ProCompTahoe
IN
you guys realize that its in KM/H not MPH? haha took me a second to figure that one out.
SunlitComet
OBS Jedi-Do Good
unknown at this time.
You got a gear vendors over drive unit?.
Look online for a instrument cluster repair station in canada or the us. They can can fix it.
If you put the 285 tires on in place of the stock with no corrections made to pcm then you should only see about 4.1% error.
EdwardsD
