SunlitComet
OBS Jedi-Do Good
I can confirm that if you upreade to the 0411 pcm ( i got mine from lextech from LS1tech.com that did my setup up for me) that the scan gauge 2 is actively receiving and processing for display x-gauges for transmission temperature on the 4l60e and engine torque on the L31 engine. i have only tried these to so far but will try others later.
here is the coding i used:
Engine Torque
txd=6C10F12219DE01
rxf=0462851906DE
rxd=3010
mth=000A00020000
name=TRQ
reads inFt-Lbs
Trans Fluid Temperature (Exc Allison)
txd=6C10F122194001
rxf=046205190640
rxd=3008
mth=00090005FFD8
name=TFT
read in Degrees Fahrenheit
Engine Torque
txd=6C10F12219DE01
rxf=0462851906DE
rxd=3010
mth=000A00020000
name=TRQ
reads inFt-Lbs
txd=6C10F122194001
rxf=046205190640
rxd=3008
mth=00090005FFD8
name=TFT
