SCG Pro - Machine Cut™ Polish
Surf City Garage
Supporting Vendor
[yt]J6lkJ8NpQR4[/yt]
SCG PROFESSIONAL MACHINE CUT™ POLISH
Remove swirls, scratches, and 1500 to 2000 grit sanding marks with SCG Pro Machine Cut Polish. The custom hybrid-abrasive blend utilizes two distinct types of cutting agents to provide powerful swirl and scratch removal, but still finishes down so clean, often eliminating the need for a second step! Absolutely no silicone means, Machine Cut™ Polish is body shop safe and effective with dual-action, orbital, and rotary polishers with foam and microfiber pads.
Discover what perfection can look like with the amazing paint correcting power of SCG Professional Machine Cut Polish!
Directions:
NOTE: Always begin with a clean and dry surface.
  1. Prime pad by applying approximately 10-12 pea sized drops of Machine Cut™ Polish evenly over the face of a moderate to aggressive polishing pad.
  2. With machine at low speed, spread product over section to be polished.
  3. Increase machine speed and work the polish until it appears thin and oily
  4. For additional panels use only 2-4 additional drops of polish.
To prevent product buildup, clean or replace pad as needed.​
ScubaJim
He looks a little thinner and younger. Maybe pre-Adams?
S
Surf City Garage
Supporting Vendor
Good Afternoon Everyone. Dylan VonKleist is the Director of Product Innovation for Surf City Garage. Yes, you have seen him previously (also myself) in the videos from Adam's. Both of us moved on some time ago and wish nothing but the best for those guys!
This new line is something Dylan has been dreaming up for a long time, and is now coming to fruition. If anyone has any questions, please let me know!
Thank You,
Mook
res51cue
