Seafoam
Denali0229
FL
My truck just went over 60k miles. Will it be worth doing a Seafoam application on my truck? I'm hoping it might help my gas mileage some b/c right now its horrible. Also, which valve hose do I put the Seafoam in? I'm a total newb on engines. I watched a few videos but I'm not 100% positive. Supposedly I take 1/3 and pour it into the valve hose, 1/3 in the oil compartment and the last 1/3 in the fuel tank then wait about 10 minutes. Then I drive it around 10-20 miles. Sound right?
sumo
dn ʇǝƃ ʇuɐɔ & llǝɟ ı
rhode island
you can pour a little at a time through the brake booster hose. I just use it in the gas tank and the rest through the brake booster hose. You can rev it on the spot and sometimes make a smoke show and sometimes nothing at all.
domin8
Just Plinking
Highland Park, IL. Transplant from SLC, UT to redu
Like Sumo said, do it through the hose that comes off the brake booster. Make sure the engine is running when your do this and don't pour too fast or you'll stall your motor. I also put 1/3 into the gas tank and use the other 1/3 on the oil right before I do an oil change.
dirt
