Service 4WD, ABS Lights On In Dash... Troubleshoot?
SeanEboy
I've finally had it! I want to fix the Service 4WD, and ABS Lights that are staring me in the face every time I drive this truck...
I've gotten stuck on the beach, with only two wheels turning - so I'm assuming I need to swap out the front axle actuator - A1 has it for $60, that seems pretty cut and dry... I've gotten it to shift when whacking it with a hammer, so I'm assuming this will solve this issue.
However, what about the ABS? I was told that the controllers go, and to grab one out of a junk yard... But, how do I know it's not a speed sensor? Would that cause the ABS light to go on? Is this something that I should bring to the dealer to have a code read? Will that give me more information as to which way to go?
Any help is greatly appreciated!
Ceejkay
Ft. Lauderdale, FL
i cant really help you out, but i occasionally get the abs light if im on the beach in 4h and getting on it in super soft sand.. i would start with fixing the 4x4 issue, might take care of your abs light.
S
SeanEboy
Well, I've only done the actuator so far - which I was told by a shop "worked when you hit it with a hammer".. So, I figured that was a smart item to change out.. But, I do have the "Service 4WD" light still going.. I'm assuming it is the switch, because the lights flicker on and off with no rhyme or reason to them.
When I start the truck, the switch is lit, then it eventually goes off. I also noticed that the issue might be in the wiring harness, as after pulling the dash, I noticed the lights stayed lit.
SunlitComet
OBS Jedi-Do Good
unknown at this time.
Any shop with a good snap or otc scanner can link to the 4wd module and give you the code that the light is on about. Bring the code back here for full breakdown.
Joe-ty
