service 4wd light on
yukonrob
shade,oh
4wd has been working fine...today the service 4wd light came on and wouldn't go into 4wd. I unhooked the neg batt terminal thinking it would reset something and it worked. probably temp fix. anyone give me some advice...thanks
BRUTUS_T_HOG
Clean up the grounds under the drivers door hinge on the body mount bracket and disconnect battery again. There is a TSB for cleaning the ground and the encoder motor position switch also sometimes needs to be replaced.
My Yukon does this from time to time I usually just shift through all the transfer case positions and it goes away for a while. Cleaning the ground significantly helped
SunlitComet
OBS Jedi-Do Good
unknown at this time.
Your Autotrac 4wd system is storing a trouble code that will explain why there is a problem but you will need to get your hands on the right scanner to interface with the TCCM. Find a shop equipped with a high end Snap-on or OTC scanner. You can not access it any other way.
