Service Airbag light
Thumper8302
OKC, OK
could be a number of things. my light is on as well.. just luck under ur dash and under ur front seats for starters at all the wires and connections. if u dont find anything take it and have the code scanned... more than likely u will have to take it to the dealer for the codes like $90 or somethin like that... best of luck to ya
and on a side note u might wanna throw ur specs out there like year, trim, model, mileage... those lil things are helpful to us
firebane
mine is on too.. but I know its because my wheel bearing on the driver side sounds like a rusty chain when driving hahaha.
Thumper8302
OKC, OK
a wheel bearing can throw an airbag light? hmm never knew that.. i thought it was just speed sensor and abs crap that got messed up with a wheel bearing
firebane
4x4 truck has some sort of sensor running from that area.. so I assume its a abs sensor.
And I know my ABS does not work as well.
brassknucklemafia
phoenix
mine is on as well, but thats due to a shattered front sensor. need to find a junk yard with late model parts that wont try to **** me royal on prices.
D
demon71
Went from a airbag question to a wheel sensor reply, thanks for no help
2007tahoeGuy
Houston
My airbag light is on as well. I took it by Autozone and it's not throwing any codes. So I called my sealer's service department and they said it was probably a pretensioner gone bad. Still haven't fixed mine so I can say what it was for sure, but thought this might help you narrow it down.
Specs: 2007 Tahoe
Helmetgurus
