Service Stability error
Ramanonos
Hello first time poster. I have a 2005 Yukon XL and there is a error light that is saying "Service stability". i've been poking around the various forums and it seems as though it could be either a sensor problem or a wheel bearing problem. Is this something I should investigate myself or take into a mechanic?
Joshuasvt
Everett, Wa
Subscribed-I've been getting the same error. Only when driving down the highway. It will flash on for about a second and go away. It's happened twice in the past few months.
jcevans7
Friendswood, TX
Take it to o rileys or auto zone. Their scanner might be able to pick up the error code even if you don't see one on the dash. That code will better help you troubleshooting so your not shooting from the hip.
Sent from my SM-N910T using Tapatalk
Jonathan Davis
i had this same error but i was corrected after an alignment. From what i understand it could also be a bad steering wheel position sensor
ivin74
05 NBS Nali
Htown, Texas
Ramonos did you ever get this issue fixed? My suv is doing the samething
plazola132
