Service tire monitor system.
ColoradoPPV
Appears at startup and randomly while driving. Dashed lines in psi tire diagram. How do I reset the system?
2015 Tahoe PPV
ColoradoPPV
ColoradoPPV
Read to much pressure will trigger the message. Had 40psi when it does work.
Will try 35 psi. Anyone have better luck with lower pressure?
Rick M
37 PSI is the recommended pressure if you're running the 17" Goodyear Eagle RS-A tires. I think the directions to re-callibrate the system are in the owner's manual.
Tahoe4
