Service traction control
Trose
im deleting all components from Autoride rear springs and shocks installed. After I pulled my pump and lines off im getting abs and service traction control messages coincidence??
T
Trose
Thanks alot great forum
sarneson91
Alexandria, VA
lol you posted at 0515 and are mad that noone has responded by 0740, give it more than 2 hours for people to get on here, a lot of the people start replying after 0900, and you have to take into factor some of these guys are on the west coast so will probably be asleep. To help in answering your question what all did you utilize to delete autoride?
sarneson91
Alexandria, VA
also this would probably have a better response if it was posted in one of the suspension sections vice the engine and drivetrain
Kraig
To answer your question: yes, likely related. And by likely, Inmean almost for sure. Did you add resistors to make the computer think they system was there and operating properly?
kbuskill
NE. FL.
Most likely culprit is the ABS sensor plug that sits up near the upper shock mount of the rear shocks on top of the frame rail... it's very very easy to unplug them while unbolting the upper shock mount...
Check there first.
Dnozgodlike
