Severa problems happened all at once.
run77
No power drivers side seat and window, no turn signals or hazard lights, brake lights stuck on, no power winfo drivers side rear, no power window rear passenger side. Passenger side front has power window and seat adjustment, but heated seat don't work...
Info center messages are....service trailer brake system, service tire pressure system, service 4 wheel drive system and maybe one other, can't think what it is right now. I replaced the bcm $200,,,, no help. The other thing is no power sun roof. What do I try now...obviously I did check all fuses and relays.
Chad G 1979
In a 21 or newer ride? Are you out of warranty already? If nit, take to dealer and have them fix it for free.
Fless
Super Moderator
Elev 5,280
Welcome to TYF!
Obviously this is not in the right section as I doubt you've changed the BCM on a '21+, so let us know what you're working on and we'll get the thread moved accordingly. That will help us help you. Year, make, model, etc. and consider adding it to your signature.
For the DIC messages, you need to get an advanced scanner (like a Tech 2) on it to pull the codes.
Welcome to the Forum from NH.
Pics of the truck, please.
You are already receiving sage advice from the knowledgeable folks on this Forum, however, we need additional information from you to assist you further..
TooManyCars
