severe vibration
apgocolts
Huntington, Indiana
ughhh i cant seem to catch a break lately. anyway i have an 03 yukon xl 4x4 and recently it has developed a sever shake/vibration around 25-35 mph. its like the whole truck shakes really bad at those speeds and decreases as speed increases. i recently also posted about a clanking sound that is coming from somewhere under the truck also. the sound increases as speed increases also. not sure if they are related or not. i have fairly new tires and haven"t done anything to the truck recently(other than change the front drivers side wheel hub assembly) that would change my allignment. any help would be greatly appreciated.
Rivieraracing
So did you have your alignment done after the hub? If so, I'd be taking it back to where you had it done and ask them to check it out since you didn't have to problem prior to them touching it!
A
apgocolts
Huntington, Indiana
No i did the hub myself, it started vibrating a few days prior to me replacing it. It has needed changed for a while now . I thought maybe the hub had gotten so bad that it was cousing the vibration. But after replacing it the shutter is still there. After replacing a hub is an allignment needed usually??
youngjs1974
Tires might need to be balanced. You might check the drive shaft to make sure it is not loose or some bearings fell out.
YukonXLPerk
I would also check the inside of your wheels to see if any debris may be stuck in them.
I had a similar shake around 65, turned out to be a bunch of mud stuck to the wheel!
Also check your tires for any blisters or bumps.
bdewitt205
