Shacks, rattles and DOSEN'T roll !!
Fire54Medic
HELLLPPPP !!! Ok, This is the first time on asking a question and for help online, but here goes. I have a 1999 Chevrolet Tahoe 2wd, 5.7 Vortec. Mileage unknown. I have changed the cap & button, spark plugs and Cam shaft position sensor. The reason I have done all these, is at around 70 mph, It starts to shack, (enough to where I have to let off gas) and misses, throws a SES code (misfire cyl. 3 sometimes cyl. 5) and acts like it boggs down, like no fuel, then catches back up like normal. Or when I pull out from like a store and give it gas it boggs down and doesn’t go anywhere till I let off the gas then get back in it..if I stay in it, it will back fire. I drive to and from work, around 200 miles 3 days a week. It will drive fine on straight stretches, but it seems like it only does this up a hill or rise. By the time I get to a parts store to read the code, I have driven on a good straight shot and the SES goes off, and no code are present. I’m tired of playing a guessing game, replacing an item to see what might fix it. Can someone please help me on what can be done next…ughhh..
Donnie Yukonie
Yates Caretaker
Moved this to Engine and Drivetrain ,
As for your problem Have you checked your Fuel pressure?
F
Fire54Medic
Fuel Pressure good tested not to long ago, fuel filter changed also forgot to mention. Also I just did this on way back from store. It started shacking going up a small hill, so I pulled it down in neutral and it quit immediately, put it back in OD, started again when giving it gas, Neutral-stopped again, this time put in drive (3rd)- started shaking..got to top of rise and straight stretch it smoothes out and stops..When I went to town didn't do anything.
---------- Post added at 12:57 PM ---------- Previous post was at 12:56 PM ----------
Gzes
the drifting 2dr
Wichita tx
Does it have enough gas? On my del sol when is low it does that. My fuel guage doesn't work so that's how I know It needs gas
retorq
Kingman AZ
Del Sol's are slow pieces of poo
thetruth.com
F
Fire54Medic
Yeah, plenty of fuel, does it on full tank and anywhere in between...
retorq
Kingman AZ
You didn't say spark plug wires, check those, they can be bad but look fine ...
2Canoes
When I think I might have a bad wire or coil, I wait until it gets dark and look at the engine while it's running. Just look for the spark. You probably knew that trick, but if you didn't... ;)
SunlitComet
OBS Jedi-Do Good
unknown at this time.
Verify fuel pressure again and when you are at the parts store have them plug in again and if possible search for pending or stored codes if they can. Also see if they can see live data and verify that the scanner rpm readout matches the dash tach at randomly selected throttle positions. It does sound like your pressure is off. Tho since you mention it happens on inclines it makes be think a valve is sticking.
mneff911
