Shaking while accelerating
massivespl
I'm not mean, I'm honest.
Michigan
So my truck started shaking when accelerating. It's not a wheel balance issue because I put different rims n tires and still shakes. I replaced u-joints acouple months ago.
It makes my steering wheel shake up n down and dash up n down and whole truck vibrates lol. Once I'm up to speed and cruising no more shakes. Any thought what it could be? I'm taking it to the shop tomorrow.
OHSIXX
Milwaukee
Still chasing down a similar issue but not as bad as you describe. Steering wheel wobbles side to side for a bit after hard acceleration. It also wobbles at random speeds for random times. I had tires re-balanced(were still good from the prior time) and had the front end looked at-nothing seemed out of place. I'm curious as to your outcome. I did do the ISS today and it helped a ton but there is still a vibration from time to time....
massivespl
massivespl
Michigan
Well it was rear Ujoints. I thought I replaced those but it was the fronts that I did. Vibration is gone now.
OHSIXX
Milwaukee
Didn't look into u joints...have to take a look. Thanks for the update.
afpj
Was there any play/wobble at the rear ujoint or play/slop in the driveshaft? Just wondering how you ended up diagnosing rear ujoints.
OR VietVet
Multnomah Falls
Military
Willamette Valley
I honestly thought that when you said you replaced the u-joints that you meant all of them and then I would have recommended rechecking your work in case you had a u-joint out of phase. Or that maybe damaged a yoke or shaft. Then you said you only did the fronts. If that info would have been shared to begin with then I would have said replace all not some. The fact that you experienced the shake when accel in the places you said you felt it, all point to drivetrain/driveline problems. Live and learn, huh! But please in the future, if you say you replaced something but you did not go all the way, then say so to help us help you.
massivespl
massivespl
Michigan
Sry for the confusion. I thought I had all the Ujoints replaced acouple months ago but it was only the front. Now I got all Ujoints replaced and smooth as butter
---------- Post added at 02:08 PM ---------- Previous post was at 02:07 PM ----------
U could tell they were original Ujoints and they had play in them
lovemytaho
02 tahoe
my 02 Tahoe 5.3 2x4 70000 mil MY TAHOE FUEL PUMP stop working I replaced AC delco fuel pump ,AC delco spark plug fuel filter and original AC Delco spark plug wires I clean intake with sea foam and I add fuel injector cleaner in fuel but still when I push gas my engine is shaking is hesitating any one can help?
No Eng. light ON fuel press is 49-50 psi this happen after they rebuilt my trans.I check my ground cables
I know nothing to do with trans but you never know any one can help?
thank you
pnwdan
Cunning linguist
Arlington, WA
hey,OHSIXX
did you ever figure out your issues? My Denali is now doing the same thing
Mazzmanian
