So after I start my Denali the shifter wont move from park. I figured out if I pump my breaks 10-15 times it will finally shift. Drives perfectly fine after that until i turn off the vehicle and then the same thing happens next time I try to drive it. I'm thinking it's the shifter lock switch (not sure if that's what it's called) but what would pumping the breaks do? Wouldn't it just not work if it was broken? This started happening after an incident where I had to slam on the breaks to avoid hitting someone in front of me who did the same. Any help would be appreciated.
2006 Yukon Denali
2006 Yukon Denali
