Didgeridoo86
- Joined
- Feb 28, 2014
- Posts
- 3
- Reaction score
- 0
This is my first post. Thank you all so much in advance.
I have a 2003 GMC Yukon Denali sport with the full tow package. 6.0L
143,000k.
OK so I have no transmission error codes. I did have a p0300 code.
So from a full stop accelerating it goes through fist gear perfectly and about when it should shift into second the revs drop off and the throttle stops working. If I take my foot off the throttle for about 2 seconds it will go into second and it's fine through the rest of the gears. Like I said there are no transmission faults on the diagnostic read out so I am really scratching my head on this one.
Trans fluid levels are good and the fluid color is good.
I had some fuel tank leak codes that I tracked down to a vent hose that was disconnected. p0452 and p0456. That might also be 02 sensor and I heard the transmission shares that fuse, is that right?
143,000k.
