Short term fuel trim %
Gordy
I have read where the short term fuel trim should aleays be between =/- 10%. Is this reading at idle, or through all throttle ranges.
The Hoe runs fine, but I got the p1071, and p1074 both banks yesterday. Nothing changed as far as how it ran, but the ltft was +35% usually it is usually+25% or less, stft was 35% was running fine. we hit -17 so it got pretty cold. So I cleared the codes to see if it pops up again.
Doing the research on the codes though got me looking at what the fuel trims should be which I did not know. Im usually in the +- 10% range with stft.
I never really paid much attention to it since I bought my code read still trying to understand the data, and what it should be with o2 sensors fuel trim ect.
Sometimes I think these codes pop up dur to water/ humidity/ cold conditions, and really are not an indication there is truly something array unless it is actually running like crap.
The Hoe runs good milage could be better.
andrew383
indiana
Have you been getting your gas from the same station????When was the last time you changed the fuel filter???
Gotcha12
