Shorter Autoride Links???? Remove Bump stops??
henrytedo
I am looking for a pair of shorter auto ride links, i bent mine as the directions said to do with my McGaughys 2/3 lowering kit and when i hit a bump my service ride control light comes on. so ill check the rods and they are down, i can flip them back up and the pump will kick on and be fine until i hit a bump and the rear will slam. So what im asking is should i get shorter link rods, remove bump stops? im lost as what to do
Mac
NY
You could try cutting it to size and then rethread ...."tap & die".
H
henrytedo
im seeing most people are cutting them and inch shorter. ill give that a shot and see,
jgrundy13
