Side molding
Has anyone removed their side molding off of their yukon denali? Was it a hard process? Any pictures?
massivespl
I'm not mean, I'm honest.
Michigan
If you take it all off PM a price for it. I might be interested. It shouldnt be hard as all. Should be sticky taped on. Alittle goo gone should take the residue right off.
chauncey0337
MLT, WA
Some use fishing line to "saw" through the double sided tape then use 3M wheel attachment for drill to remove the remaining tape.
Robert_02yukon
So it's the 3m tape that holds it on? Good my mustang side pieces were bolted and was a pain
shortbusondubs
If you rubber wheel it, it's gonna need a buff in most cases. I did my emblems a week or two ago and buffed the spots afterwards.
chauncey0337
MLT, WA
Do you think goof off would be a better solution rather than the 3m wheel
I used denatured alcohol to remove my badges. It works but much more elbow grease. Fyi, there may be a discoloration/oxidized ring around the molding. In some cases buffing will help, some cases not.
massivespl
Michigan
I use goo gone when I debadge and I didn't have to wheel or buff. You can't see any lines where the emblem was. I was pretty shocked. I have a dark green Tahoe if color matters
samoo
