I had the same concerns. But, FWIW I pulled all of the rockers when I did my cam swap the 3rd time and checked for play and smooth motion on all of them (about 12K on the BTR trunnions at the time, I believe). All were still snug and all were smooth turning. I don't plan to revisit them again unless I have to pull the heads for something again. Fingers crossed!The only upgrade I consider a true upgrade is the Max Effort kit from RPMSpeed. The bearing kits that use the trunnion as the inner race might be (and probably are) better than when they first came out. But, they rely on proper hardening of the trunnion and that's an extra possibility for failure. The Comps failed at this step when they first came out. I'm not totally sold on the brass bushing style for longevity yet, either. My setup isn't any more wild than a stock LS6 and those go for hundreds of thousands of miles on the stock rockers. I'm still using my stock 215K-mile rockers. The aftermarket stuff could be an upgrade, but which brand? How do I know the big name brand (BTR, TSP, etc. isn't a re-packaged ebay brand, all from the same source? I'll never know until thousands of miles later (years for me) if their hardening process was properly performed or if the brass (soft metal) actually doesn't wear like one would think, etc. I just don't wanna find out the hard way.
I moved my originals radially to check for slack and there was no movement. Otherwise, I wouldn't have reused them. That's why these surprised me.
I've said that if I had it to do over again, I wouldn't bother with a trunnion upgrade, but your experience with new stock rockers makes me wonder.
