Rolexus
- Joined
- Aug 2, 2021
- Posts
- 89
- Reaction score
- 95
2005 Tahoe, 4WD: Been awhile since I’ve posted… recently drove home in a bad winter rain storm. Upon parking in garage, a noticeable gas door occurred. No ‘service engine’ warning, and no codes appeared using OBD (Sorry if I’m not using the correct vernacular). Gas tank was ~ 3/4 full.
Both of the AC Delco 214-1105 - Vapour Canister Purge Valve and 241-2149 Vapour Canister Vent Selonoid were replaced when code showed EVAP issue about 30 months ago. Also replaced the gas cap with AC Delco @ same time.
Didn’t drive it for a few days, but continued looking for possible gas leaks in and around tank, gas lines and under hood - found Nada - nothing, and made sure the gas cap was securely in place.
When the weather improved, took it for ~ 10 mile drive. The gas odour being emitted has disappeared (for now…).
if this problem re-occurs, does my one have any possible insight as to where I could specifically look for the source of the smell?
Read another post by StuckinMN, suggestions revolved around fuel pump mounting plate…
Any advice greatly appreciated. Thanks in advance.
