Speakers pop when I turn off tahoe
Tapia
San Jose, CA
can some help i replace every speakers in the truck and add alpine amp 2 12" Memphis with a kicker mono amp and every time I turn off the truck it pops .... Any help
massivespl
I'm not mean, I'm honest.
Michigan
Is the woofers popping? Or the speakers? If it's the woofers then it's the amp.. I had same problem with a powerbass amp I just had... Swapped it out with another amp and pop noise was gone.
massivespl
Michigan
Sounds like you have a wire touching somewhere. If a speaker wire got rubbed or cut and is touching metal it will cause popping
AppocAlexx
Darth Appocalexx
Abilene TX
dido on that, wires touching with a bad connection somewhere from head unit to one of speakers or around your subs and amp. Also check all your grounds. Even though your amp is on a separate ground it could still send power back to other speakers via RCAs through head unit and then to door speaker. Some head units have a separate ground as well too.
If you don't have an aftermarket head unit and you used the RCAs splitter connecting to the door speakers that box could be bad too, especially if you used a cheaper brand or just a bad apple. Not sure on what set up you have but check that box and connections if you have that installed.
Tapia
Tapia
San Jose, CA
Yes I have all my speakers connected to app and new pioneer stereo .... re wire the truck for the second time check every cable change amps and subs and still get the pop when I turn off the truck
massivespl
Michigan
If you can try a different amp... I have tons of audio in my truck and I had a powerbass amp on my doors and speakers would pop just like yours.. Swapped amps to a lanzar opti 500x2 and the pop is gone... If you checked everything it's most likely the amp itself.
Tapia
Tapia
San Jose, CA
Yes they they both share the remote and I have try different amps and it keeps doing the same thing .....
eMLi
