Specific Request: Pics of Leveled Yukon on Factory 20's
garymyman
Louisiana
Pics of Leveled Yukon on Factory 20's (UPDATED)
Greetings all. I have a 2007 Yukon 4x4 I'd like to put just a 1.5" leveling kit on the front and go up one tire size - either Cooper Xeon LTZ or Nitto Terra Grapplers or BFG All-Terrains, if I spend the big bucks. I'm looking for pictures of Yukons or even Sierra's on these wheels leveled on all-terrain type tires and haven't found any. Can anyone help?
Here she is currently:
Yukon11
Arkansas
I am looking to do the same thing to mine. I currenty have the 17s and have been trying to find some of the stock 20s that aren't too expensive. I have been looking at the yokohama geolander at/s (275/55/20). You can get a set of those for below $800... Do you happen to know if your wheels are polished or machine finish?
felixgun
Lafayette, LA
I know I don't have a yukon, but I do have before and after pics of it with a leveling kit and "one size up" tires (Nitto Terra Grappler 305/50/20) on my avalanche for some comparison pictures since the yuk and avy are essentially at the same height. Hope it helps. Also, Welcome to TYF! Where in LA are you from? I'm from Lafayette.
When I got it with stock suspension/factory tires:
Stock suspension with Nitto Terra Grappler 305/50/20:
2.5" (front only) Leveling kit with the Nitto TG's:
I noticed after a 2.5" that my rear was lower then the front, so in the end I added a 1.5" rear spacer to fully "level it out".
Tmac
Here is mine with 1" spacer.
garymyman
garymyman
Louisiana
Thanks for the responses. I went with the 1.5" Pro Comp kit. I'm putting on BFG A/T 285/55r20 tires tomorrow. But here are a couple pictures of Yukon with only the level. The only decision left: White letters out or in on the BFG's...
I haven't measured yet, but the "Cali Lean" in this picture is due to the angle of the parking lot.
Thanks! I'm in Shreveport. Work was done at SS Truck & Performance.
Zed 71
Pacific NW
IMO white letters in for Yukons. I think Z71 are the only ones that can pull off the white letters out look.
SPLmonster13
Texas
I think white letters look so sweet! Especially if it's kinda "off-roadish"
garymyman
garymyman
Louisiana
I'm leaning toward black letters out. I had white on my F-150 but this is a little more "clean looking" if that makes sense. I'd have the white's out on a Z71, too.
So far so good with the level. Rides at least as good as stock and I actually feel higher up - though it's probably a placebo effect.
pipehand903
