SQUEEEEK, SQEEk, squeek, squeeksqueeksqueek-------
God
My truckhas a squeek somewhere that just recently started. It is most noticable at slower speeds, and then as you speed up it sort of goes unnoticed since the squeek intervals are so fast. What should I check? Sounds like its coming from the front of the truck.
SunlitComet
OBS Jedi-Do Good
unknown at this time.
or brake noise. the u-joint kinds will squeak about 3-4 times faster than one rotation of the wheel so it should be easy to distinguish.
G
God
So it could be the brakes even though I'm accelerating? How should I check to see if its the brakes?
Administrator
If it's brakes it'll most likely stop when you apply the brakes. So go slow where you can hear the squeak then gently apply the brakes and see if it goes away.
OHSIXX
Milwaukee
possibly brakes...like a wear indicator or something...maybe you have a caliper hanging up....
saif najd
I have the same too more like sqweek+click I think it is the transfer case I dont I am getting sick and tired of this it was fun but know ...
Sent from my GT-I9505 using Tapatalk 2
xanatost
Lafayette, La.
Check your rear drum brakes. That was where mine was at. One of the springs came off and a clip was rubbing.
shadowid60
