SSV rear door lock problems
Schwartzint1
I have a new to me 2011 Tahoe. I believe it's an ssv. It has options 6b2 and 6n6. One is inactive door handles and one is inactive door locks. The doors do lock with the key fob, but obviously my passengers need to be let out of the vehicle every time. The handles are there, just inoperable. Anyone know exactly what parts or pn I need to fix this issue?
S
Schwartzint1
After more research what I'm asking is do I need to replace the actuators, or just lock rod and lock knobs?
iLikeEggs
Potato!
Oregon, USA
I have the same vehicle. The rear door unlock handles will work once you pull the panel and attach the cable that is hanging there. It's a very simple fix. Because it was a law enforcement vehicle they leave them disconnected at the assembly line. The window switches are dummy units. You can get functioning ones, off ebay cheap. In order for the power locks to work you will need to order the connecting rod from the dealer. Also, if your rear shoulder belts are not present they are likely tucked away behind the rear pillar where they usually pull out from. Mine were just left there from the assembly line, unused and neatly bundled. You will have to order the anchor bolts from the dealer (do not use standard bolts). All of these things are easy fixes. Search my posts for more info.
S
Schwartzint1
After I posted this question I realized I had a few extra min. Why not pull the panel and see what's missing. Lol sure enough all I needed was to engage the cable with the handle. Thanks for your response. Is the connecting rod what attaches to the lock knob? Passenger side has one, drivers does not. Kind of strange.
iLikeEggs
Potato!
Oregon, USA
The lock knob pull button will sit right on top of the linkage.
There's a parts diagram here. Item 5 is the part you are looking for. Be sure to get the right and left ones.
http://www.gmpartsdirect.com/auto-p...m/5-3l-v8-flex-engine/body-cat/rear-door-****
iLikeEggs
Potato!
Oregon, USA
Technical service bulletin of interest.....
Bulletin No.: 07-00-89-004H
Date: June 14, 2012
Subject: Special Equipment Options (SEO) on Police Vehicles
Models:
2006-2013 Chevrolet Impala (Police Vehicles Only - RPOs 9C1, 9C3)
2006-2013 Chevrolet Tahoe (Police Vehicles Only - RPOs PPV, 5W4)
2011-2013 Chevrolet Caprice PPV (Police Vehicles Only - RPOs 9C1, 9C3) Supercede:
This bulletin is being revised to add the 2013 model year. Please discard Corporate Bulletin Number 07-00-89-004G (Section 00 - General Information).
- Dealers should be advised that due to certain Special Equipment Options (SEO) available on these police vehicles, other components have been intentionally disabled.
- DO NOT enable these other components as it causes confusion when the vehicles are delivered to the police.
The following table provides details of each specific SEO. These features are normal for police vehicles.
182162418
CrashTestDummy
Pearland, Texas
That was one of the first mods we did when we got the Tahoe. The lock knob at the top of the door panel and the linkage were not there. Funny, when we got our '12 Caprice, and was going over it, I discovered a pair of Tahoe lock knobs and links zip-tied together, laying in the spare tire well. Score!
I'm still conflicted on getting the rear window switches, or not. Our only rear seat passengers are our 4-legged kids. Not sure I want them playing with the window switches. o_O
iLikeEggs
Potato!
Oregon, USA
Awesome score!
You could always override the rear windows from the drivers master panel. It's worth it to fix it. Otherwise it will forever be nagging at you in the back of your mind. Lol.
CrashTestDummy
Pearland, Texas
Actually, it doesn't bother me in either vehicle, since I'm rarely back there. IF I run across someone parting a Tahoe, and can get a deal on the switches, I might consider it, but having the inside door latches work is plenty for me.
S
Schwartzint1
All I need now is #5. I only need it for the drivers side. Everywhere list as left and rt side. I'm assuming left is drivers side. Can you clarify that?
dph1994
