First off, welcome to the forum from Iowa.My service Stabilitrack and traction control lights keep coming on. I can clear them but then they come back. I have had a few times in the past week my battery had been dead. Anyone else have this issue? Thank you!!!!
How are you clearing them? Are you able to read any codes on a scan tool? If you have codes, what are they? Autozone will read your codes for free if you don’t have a OBD2 scan tool. Just make sure they give you a print out of the codes they pull.
Under what conditions do the lights come on?
Any work done recently to your vehicle prior to this happening?
How old is your battery?
These vehicles hate low voltage and bad grounds.
The on off switch that turns the stabilitrack and traction control on and off but it doesn’t always allow me to do that. I used a code reader and nothing comes up. And I would assume the battery is around 4 years old I just got this truck 2 years ago. I haven’t had anything done to it since I got it. Just the normal oil change and brakes That’s about it. Thank you for replying
You may need to get a higher end scan tool that can read more codes like ABS and SRS because there most likely is a code or two associated with the messages.
As has already been mentioned, bad speed sensors can cause this, as well as a bad steering wheel position sensor, and host of other things like a bad battery like Paul just suggested. If your battery is 4 years old, take it to Autozone and have them test it and also have them scan for codes.
When I get 3 things that pop up on the scanner $07E8. $07EA. And $07EBYou may need to get a higher end scan tool that can read more codes like ABS and SRS because there most likely is a code or two associated with the messages.
