Stalling
Saint_La_Ron
I have 2008 denali 6.2...It starts up fine but when you either slow down or come to a stop it stalls out. I've changed the crankshaft & 2 of the 02 sensors that came up on the scanner yet it does the samething. After 2 start ups the stabilizer light comes on the truck will drive without stalling but the rpm on the dash doesn't move. Anybody else ever encounter this issue?
Fless
Super Moderator
Elev 5,280
What codes "came up on the scanner?"
When was the throttle body last cleaned, and is it clean now?
Test the IAC function. Any vacuum leaks?
When you say you changed the crankshaft I'm going to assume that you mean the crankshaft position sensor. After changing it, a CASE relearn should be done with a capable scanner.
Welcome to the Forum from NH.
Pics of the truck, please.
These trucks are very sensitive to electrical connection and ground issues. I would first check all grounds in the engine bay, particularly the braided ground wire from the engine block to the firewall. Then, check the ground on the frame underneath the truck, approximately below the driver's seat.
What do you show for fuel pressure, as the engine starts to fail?
S
Saint_La_Ron
I did the relearn after changing the sensor....The code that are coming up are P0336, P0335, P0420 & P0175
seventwelve
