standard shocks for autoride
02chevyhoe
is there any standard shocks that will fit right into my autoride suspension after i use resistors to trick the autoride
NathanJax
Vacation Nathan
Administrator
Jax, Fl
Any shocks for 99-06 tahoe yukon etc. will fit. I have Bilstein HD Front Shocks #F4-BE5-6500-H0 and Bilstein HD Rear Shocks #F4-BE5-6501-H0.
No need to trick the auto ride using resistors. Just remove the negative from your battery, pull the RTD fuse under the hood, and replace batery cable.
NathanJax
Vacation Nathan
Administrator
Jax, Fl
what happens when you don't have a RTD fuse and have the light on the dash?
The dash light won't light up because the entire RTD system doesn't have power. It's off, so nothing to do with the RTD works...
02chevyhoe
thanks for all the replys/help wich is the rtd fuse under the hood? will it be labeled as rtd.. i was on my way out the door to look for it but its pooring right now lol
Meg_az19
