starting issue 02 Tahoe
slicksdude
Hello need help my Tahoe won't crank won't start battery is New. Symptoms when turning key over it only makes a click sound 1 click. Repeat same thing. I Keeped attempting due to being stranded at work. Long story short I had gave up rolling up my windows I decided to give it on last shot. And guess what the son of a ***** started. After 45 min.
I've had this issue before in rare occasions once every 6 months it will do the same but after 6 attempts of turning the key it will start.
Help me out guys need my hoe back on the road.
mooman
Saint Paul
Dirty connections at the battery can seem like a dead battery and cause one hell of a time. Also, how old is your starter?
domingo cardenas
It's your starter relay. just get a new relay, but wait til the car fails to start, then pop in the relay to verify that was the issue.
SLCHOE
ASE Master Certified + (L1)
Midvale, Utah
Most likely a bad starter.
Next time it wont start and just clicks once, have someone sit in the car and hold the key in the crank position while you get under the truck and tap on the starter with a hammer (TAP not POUND lol). If you tap it once or a few times and it cranks, your starter is about done.
This is assuming the "click" is more of a "clack" and coming from under the front of the car rather than a soft "click" from the fuse box under the hood.
slicksdude
slicksdude
Connections are clean, never changed the starter since owning her going on for 8 years now. Bought her pre owned at the dealer doubt previous owner changed it.
slicksdude
slicksdude
Sounds more like a soft click from the fuse box to me. That's where I've managed to hear it from. Didn't know my starter was under the truck. Where exactly is it?
Malden11b
