Still running hot with new radiator
newbie78
So I finally got my new radiator a Spectra and I'm happy no leaks!:rockit: but now it still runs hot about 220+ The needle goes to about 3 little lines above the 210 mark but back down to 210-215. Never gets under 210.
I am ordering a new ac delco water pump and replacing the coolant temp sensor and sender. I got a new radiator cap and Stant superstat thermostat too and it doesn't change anything.
How do i know if air is in the system?
Also another thing I NEED to do is change the ignition lock cylinder it's getting worse where I can't turn the key on. Takes a couple mins of fumbling with the key to get it to turn.
I'm ordering an Acdelco replacement for $20 but it says it needs programming at the dealer? Anyone have a right up on how to do this and does it need programming?
It's a 1997 chevy tahoe 5.7
thanks
Donnie Yukonie
Yates Caretaker
As far as the overheating goes did you "burp" the system of Air when your first ran it?
N
newbie78
Can you explain how to do that? And if I didn't do it right the first time I ran it how can I burp it now?
thanks
Donnie Yukonie
Yates Caretaker
[yt]zUpXgAJ1gjU[/yt]
This is how its Done :driver:
---------- Post added at 05:12 PM ---------- Previous post was at 05:05 PM ----------
Here is another , I found,
[yt]BQk9HpuIrmA[/yt]
Forgive me about being lazy to type but I haven't had much sleep today , as for your Ignition key , I may be wrong but I think you do intact have to get it programmed at a dealership (NOT SURE) hopefully someone chimes in and backs me up or calls me out on it .
N
newbie78
thanks I hear you on the sleep part lol
It's weird I have burning hot heat to the point my damn shoe feels like it's going to melt if I dont move my foot. I don't think i have air in the system if I have the hot of heat.
I will see what happens after i replace the water pump and temp sensor and sender. Gotta drain all this coolant out in a week anyway to install this stuff.
NathanJax
Vacation Nathan
Administrator
Jax, Fl
I fixed our lazy moderators post for you
:Handshake:
