MassHoe04
Long time no post! New job with agency take home vehicle and very crazy summer with work, so nit much time either the Tahoe and a few short trips cross-town.
Time for annual safety inspection... fail. Upper ball joint was bad.
Upper control arm bolts would not budge with hammer, so I went and got an air hammer. Still no luck!
I failed RMV safety inspection with bad upper ball joint. Bushings look like crap, so I wanted to replace the arm with new assembly. I gotv the ball joint out of the knuckle, but I could not get the two bolts out at all.
Decided to pick my battles and just do what needed to be done to pass inspection. Popped a new ball joint in. At some point, I'd like to get the the control arms next spring when it warms up again.
Tips/tricks/procedure suggestions? I know I'm not the first to have this happen...
Cut through bushings and both ends of the bolt with cutoff wheel? Is that best or only way? Would need new bolts at that point.
Thanks!
Thanks!
