Suspension torque spec info
Fifty
Can anyone list the torque specs:
Front Upper shock bolts
front lower shock bolts
Rear upper and lower
Sway bar links
upper and lower ball joints
rear track bar
If you have them, anything from the brakes....
(I did a search and couldnt come up with anything. This would be a decent repository)
I’m on a 2015 Yukon xl Denali 4wd
Can you list your truck year/model/trim, in case the torque specs are different foe different years?
I am in the process of upgrading sway bars on my 07 Yukon XL Denali, so I can help you out on a few torque specs.
Sway bar end links - 17 ft lbs (from another member on this Forum)
Sway bar U-shaped center brackets - 25-30 ft lbs
Other folks will chime in one the rest.
patniven
