Swap 95 engine into a 99
mattbau43
I have a blown engine on my 99 yukon. I have a 95 5.7 non vortec engine. Are these the same setup? Can they be swapped out?
grimm
Bay Area, CA
You could swap an older TBI engine, but you would be losing the Vortec heads, thus losing some efficiency and power.
I would just get a remanufactured replacement engine. Wouldn't cost you that much really in the long run if you were able to swap it yourself.
grnrpr68
Davenport IA
agree with grimm u can get a reman motor for pretty cheap then you can just sell your 95 motor and pay for the new one
retorq
Kingman AZ
Swap the top end and cam out off your 99 into the 95 block. It should be fully setup to run the roller stuff ...
Tahoefred
