Swap jumpseat with console
missta
Nork, NJ
I wanted to know if its an easy swap from jump seat to full console?
02 Hoe 4wd canadian built flex fuel ls non bose
YukonXL04
The Riverboat
Arlington, TX
depends on what you call easy. But for the most part yes its an easy swap. You have to remove both front seats to remove the jumpseat. then remove the glove box lower dash, put the new lower dash in, and then install the console. then put the front seats back in. just make sure the console brackets are underneath the front seat brackets.
missta
missta
Nork, NJ
Thanks...I'll pick it up. I want to black out my interior anyway, so removing the seats is necessary. I'll go for it cause its a good price. When the spring hits, I'll install
travishunter2016
