Swiss Cheese Mod
bankswood
As I read through the thread "What did you do to your Tahoe today" I keep seeing something about a Swiss cheese mod. I assume it has to do with drilling holes in the bottom of the airbox creating greater airflow. Am I correct and does it have a noticeable improvement in performance
Physh1
In combination with other mods, yes, it can have a slight seat of the pants improvement...since it's free it's even better.
ezdaar
Chat Troll
Redneck central, Aka Houston
remove airbox completly, remove metal plate from under air box.
2 methods toopening airbox.
Cut out entire bottom leaving just the mounting boss's
OR
use a bigass hole saw bit to cut out four 4" holes in bottom of airbox.
Best method? cut out entire bottom.
Buy 4" pipe and silicone adapaters and make your own tube from MAF to TB.
Not you have a HDR (Home Depot Racing) CAI, it works very well for the 40$ you will spend on pvc and silicone adapters.
Remember, theres NOTHING different between a K&N, AEM, Specter, etcetc TUBE! They are simply TUBES
Its where you get the air thats the biggest issue. Stock airbox with no bottom is absolutly the best, in terms of cost VS performance.
My AIT's run 199 @ idle with specter, buddie runs the HDR setup above, his IAT's are 178.. I knw this by my predator programmers real time diagnostics setting.
B
bankswood
Thanks. Why would replacing the OEM tubing improve air flow?
ezdaar
Chat Troll
just pull it out one day and look, you will know.
The oem tube is a hemholtz resonator. think of it as a muffler but in reverse.
B
bankswood
Thanks ezdaar. sounds like a simple mod.
Why would GMC choose to restrict airflow when a simple straight hose would increase performance
TheYuk
Atlanta
the main reason is to quite down the air flow noise. With a straight through intake you will here the air flowing through. kinda like when a 4 barrell carb opens up.
ltdan
Anybody have pics of their HDR intake?
Sent from my DROID X2 using tapatalk
B
bankswood
Yeah, I'd like to see it. I plan on cutting the entire bottom of the box out. Will that alone significantly increase air flow or do I need to cut some holes in metal plate also?
Maisie14
