switch wire /wiring bose premium
southbeach
I just installed an different head unit because i live in germany. everything seems to work except the amp is no switching on. Can anyone help which wire is switching on the premium bose amps and maybe some has an wiring diagrams for the desno connectors...
thanks in advance from germany
the car is an 2009 yukon denal with bose premium and nav
bauer4567
Allentown, PA
you can catch a remote wire from you ignition harness (steering column). The radio power wire in the back of the head unit is a weird setup through the GM Lan system.
The yellow wire however (i think its yellow, check me on that), but it is the "illumination" wire. What I did was attached my remote wire to this. It sounds weird, but fits my purposes very well. When I am driving around for work, or have people in my car, I typically do NOT want the extra bass, but at night, I almost always want the bass. Well, when the headlights come on, the amp automatically comes on. Basically, the amp is controlled by the light sensor on top of the dash. If I Do want to listen with the amp during the day, I can just turn the fog lights on, or switch the headlights to the on position. I prefer to do the fog lights, because they just turn off when I shut the car off, as opposed to having to switching the headlights back off. I also put a switch in the bottom of my center console, which I can turn the remote wire off completely, so that no matter what my lights are doing, the amp will not be on...
Anyway, if your looking for just a standard setup, you have to go into the ignition harness in the steering column, I believe.
S
southbeach
Sorry i think i meant a different thing i installed a new headunit, with a lot of harnesses but i think the remote 12 volt to the original bose system is not connected. I need to know which wire comes from the premium bose amp to the 4 original connectors in the back of the original headunit(denso)(grey, black with power cable), brown, black
bauer4567
Allentown, PA
Oh, the factory amp wont turn on?? I got ya.
If you take out the cup holder area (comes out pretty easily with a screwdriver w/ electrical tape wrapped around the tip), you will be able to see the factory amp and all the wires going to and from it... If you locate that, and then compare to what you see in the back of the head unit (or original factory harness), you should be able to ID those wires pretty quickly....
bobbydon99
