Sylvania Zevo The Night Sun LED DRL 4157 package (45Watt Equivalent? )
BG1988
I think I found the brightest LED lights in the 4157 package(also 3057,3157,4057)
45Watt Equivalent
the two led didoes is like looking at the sun
I got some Zevo leds awhile back and though it was garbage as it had pink out of the red lens it claimed it was for red lens
ok so i popped off the lens cover to revel two led chips ok and tried it again and noticed it was much brighter then without the lens defuser
they might be usable as the DRL how does the SUV respond to using LED in the DRL part?
AL8806 is a step-down DC/DC converter (LED driver)
it says it will accept voltage range from 6volts to 36volts.. that is how i can power it with a 9 volt battery
