Tahoe Brake problem
alanb
london
I have a 1996 5.7 Tahoe when braking the brakes are really good but when I have slowed down to about 5mph using the brakes the pedal goes hard and there is a groaning noise coming from the brakes, if I release the pedal and press again the problem clears, does anybody have any ideas.
98chubby
Is it a grinding noise? Did you check the pads? Possible caliper getting stuck?
BattelWagun
Chi-Town USA
Is it a 4wd? If so, your front hubs are bad! Its most likely a bad speed sensor which is causing the ABS to engage a slow speeds, because the system can't accurately determine wheel speed anymore. it's a very common issue on these trucks. I know the 2WD can do the same thing, but it's a much cheaper fix.
BattelWagun
Chi-Town USA
Basically, if it is your hubs, buy a new set and bolt it on. The only special tools you'll need are a big socket for the axle nut (32mm i believe). Then theres only three more bolts on each hub that hold it on. Really simple job.
A
alanb
london
I fixed the problem on my truck, the discs and pads were worn so I replaced them with Bremo discs and pads, also whilst it was apart I pulled the ABS sensors out and cleaned off the rust layer between the senor and the hub (read that somewhere on this forum) and the brakes are now spot on.
Well Worn Chevy
