Tahoe Shaking
TnTahoe
TN
Well when im coasting along in drive I can feel a slight shake in which I think is coming from the rear of the truck anyone have any clue what this could be and or what can i check to make sure everything is ok, oh yeah this is with my stock wheels on
Z-56 Hoe
What do I do????
Houston
does Your ass Vibrate? is so maybe a rear tire is outta balance? U-joints check them. Maybe a flat spot on one of the rear tires?
TnTahoe
TnTahoe
TN
tires are basically brand new but also my truck does like this clunk thing sometimes when i stop and i was told that is a symptom of u joints possibly needing to be replaced
Administrator
I'd definitely take a look at the u-joints. Bad u-joints could cause these symptoms since you said your tires are virtually brand new....
TnTahoe
TnTahoe
TN
i also get a shake on the highway around 75, or i should say it intensifies
Administrator
Is it just the rear that shakes or can you feel it in the steering wheel too?
I have heard of new tires being bad ("defective") but it's rare.
TnTahoe
TnTahoe
TN
well at highway speeds the entire truck shakes a lil, but i dont think the steering wheel shakes much
Administrator
This still could be the u-joint issue so I'd get that fixed first since it's pretty cheap and easy to do. If it's still occurring I'd also wonder if it could possibly be a drive shaft slightly out of balance but I'm not sure if it'd cause more several "shaking" than what you're describing.
TnTahoe
TnTahoe
TN
i was thinking also that my rear bearings are wore out but i havnt noticed any noise back there, but under hard braking my truck does pulsate or something
Administrator
Pulsating upon braking usually points to warped rotors but that is most likely a separate issue from that of shaking as you move down the road.
I'm with you on the rear bearings. Normally you'll hear noise coming from that area as the vehicle moves if they are going bad.
dry_fly
