Tahoe surging but not brakes?
andyweder
Hello all,
I am new to this forum, as we have purchased a 2009 Tahoe a few months ago. The vehicle has 130K miles. After owning it for a couple weeks, I noticed a vibration when braking. I replaced the front and rear drums and pads. I also recently replaced the passenger side wheel hub/bearing assembly. The braking vibration is gone, but the vehicle is not right. When slowly braking, it feels like it is "surging" when coming to a slow stop. However, when brakes are applied somewhat aggressively (50+ braking force) it comes to stop smoothly. Any ideas on what to check/replace? Thanks all!
cmc76
how do your rotors look?
or when you say drum, are you referring to rotor?
David Smith
Savannah, GA
I am not sure what exactly you mean by surging, but my Tahoe acted funny when I replaced my wheel bearing initially. After I replaced mine, once i got down to about 5-10 mph, the brake pedal would push back at me (like the ABS was engaging). It made it where I could not stop quickly sometimes.
My problem was there was a little bit of built up (dirt, rust, whatever) under my ABS sensor when I put it on the new wheel bearing. This caused the sensor to be too far away from whatever it senses on the inside (by too far away, i mean like the thickness of a few pieces of paper). I took the sensor off, cleaned it as well as where it mates to the wheel bearing, and the problem went away.
schaffer05
Possibly air in your brake lines.
A
andyweder
By "surging" I mean it does not come to a smooth stop. Feels like the rotors are warped, but I just replaced them. It seems to get worse the more the brakes are heated up. I do not feel any vibrating or shuttering at higher speeds (above 10 mph). It just does it when I am rolling to a stop... weird huh?
David Smith
Savannah, GA
Like pulsing? You can feel the whole car pulse to a stop?
A
andyweder
Yes, exactly. I can feel it in the whole vehicle and not just the front end or rear end. "Pulsing" is more accurate. I just drove it home and did a test again at higher speeds, pushed the brakes pretty hard and it is smooth... It just happens when rolling to a stop....
JetBlackNali
Vancouver Canada
Does it feel like warped rotors? Was it very rusty and or dirty? My bet would be the rotors are not seated properly. Have had this before. Doesn't take much.
chadfranks
