tb ss seats
trublew
does anyone know if trailblazer ss seats fit in a 02 tahoe ? are they bolt in?
Administrator
With the tb being much smaller I'll go out on a limb and say they are not "bolt in" but you might still be able to make them work.
T
trublew
just found front and rear tb ss seats for 200...thought itd be a nice swap...and i have a squeak coming from under my ds front seat that i cant find....
LuSe4
Bleen Member
Michigan
Also, are the seatbelt incorporated into trailblazer seats like a Tahoe?
Administrator
Definitely a good question from Luse! :waytogo:
For 200, If they're in good shape then grab them. I'd the seat belt thing works out then I'm sure there's a way to make them work!
T
trublew
they do have the belts im just worried about the brackets
Administrator
Then I'd take some measurements and compare. If they're close then you can fabricate something up pretty easy to adapt the tb seats to the stock bolt locations. I'd also measure how tall the seats are from floor to top of the seat cushion to see how much higher or lower the tb seats might be.
JGARZA2213
Valparaiso, IN
The TBSS seats will definitely not be a direct bolt in. I have both a Tahoe and Trailblazer, and have removed both front and rear seats in both, they are not the same setup. I am sure you could make them work with a little elbow grease, and alot of welding, but in my opinion wouldnt be worth it. Are the seats you found leather? If not, It would be much cheaper to just have "SS" embroidered on your current setup.
T
trublew
no, they are the cloth seats... i like the two tone on them, and they are a good price, thats why i was going to pick them up...but its not worth it if theres a ton of welding to do...
CoyotesRUS
