Tcase issue
turk
My tcase shelled out on my 99 Tahoe. Replaced it with a reman. Everything hooked up nice, plugged in all connections, vacuum line, and checked fluid levels. I replaced the electronic gear switch on the side of the tcase as well.
I did pull the Tahoe into my garage under its own power. Transmission seemed fine and have had no issues with it.
Now that I replaced the tcase the Tahoe will not move under its own power. Does not matter what gear I put it in. When I put it back into park after switching to any other gear it makes a short grinding noise.
One other thing.... in park I can roll the Tahoe. Actually in any gear it will roll when I push it.
Any help would be appreciated as I’m about to push this thing into the river.
Thanks in advance.
turk
turk
I will add that I purchased a reman online from The Gear Shop. Supposedly built “bulldog tough”. Not sure if anyone has used them before, but I am not too impressed with their customer service.
They seemed a little irritated with all my questions and had zero troubleshooting support besides “send it back and we’ll check it”. I’ve already been down a week due to length of tcase shipment and I have 10+ hours in removal/install and troubleshooting myself. Not really wanting to send it back if there is another issue.
MaBs413
NJ
Question... Did you solve your problem?... I think my transfer case is going...
Phone Man
Long Island NY
Is the grass in neutral? If not, did you get the correct trade for your transmission? One is for a 4L60e and the other for a 4L80e. They have different input shafts.
jeff ashworth
Thanks in advance.
Sounds like your T-case is in neutral
kevinwhite
