NoReverseYukon
I bought an instrument cluster with the trans temp gauge to put into my 1500 series Yukon and the speedometer reads approximately 10% fast through all speeds. I thought it would be as simple as doing a speedometer calibration but the T2W says it is not needed, so then I thought I would change the tire size to see if that would cause any changes. The stock size is 265/70/16 so I changed it to 285/75/16. The speedometer read the same 10% fast, so obviously that change does nothing with the cluster and I changed the size back to original.
Next, I though maybe the needle is not in it's correct position on the air-core stepper motor. This not being the same type as the later-type steppers, I don't even know to determine where the correct position is.
So, I did a gauge sweep. Even though my speedometer is 120 MPH, the needle only went up to 55 MPH. Well that sucks ! I was expecting it to travel up to and over 60 MPH - that would explain the reading being faster than the GPS read.
For those who might have messed around with these speedometers, a few questions :
1) Will changing tire size then trying a speedometer calibration yield better results?
2) Is the T2W even capable of correcting an inaccurate speedometer?
3) Should the gauge sweep test have the needle stop at 55, instead of 60 even with a 120 MPH dial?
4) What has me even more stumped is that I actually have 2 clusters with the trans temp gauge - the one installed now is reading fast while the other one reads slow. This leads me to believe that somewhere in that BIN file is a value that can be adjusted to calibrate them. Which means that they can be calibrated - but maybe not with the T2W.
The local GMC/Chevy dealer says he can do this, in addition to adjusting the odometer. if I can, though, I would like to solve both of these problems myself.
Thanks for any and all help that is offered.
